Dashonthedash
Jul 24, 2013Explorer
When you switch over to gas, listen closely; you should hear the ignitor clicking and then the flame will come on with a "whoosh". If you don't hear anything, or it won't stay on, Chris may be right: you may have something in your gas lines or in the fridge ignitor system. Make sure your propane supply is turned on, check your level (at the tank) and try the other propane appliances, including the furnace and the stove and the hot water heater, to see if they work. If they're OK, chances are you have a dirty or bad ignitor system.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
