hydrocynus
Feb 28, 2017Explorer
Chris Bryant wrote:
When you are checking points on the board for 120 volt power, are you actually testing between the board neutral and hot, or are you just grounding the meter and testing for power? Also are you testing it under load- i.e., turned on set on AUTO ?
I have tested it by removing the rubber caps of the plugs of the AC input and the meter reads the right voltage. I also unplugged the AC plug and plugged it onto the main power input to the construction site. The fridge still switches to LP automatically (under the AUTO mode).
This is a great forum guys! Thanks for your help!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
