hydrocynus
Mar 04, 2017Explorer
Chris Bryant wrote:
That is the correct board if the original had the integrated ignition module. Does the AUTO light come on but it stays on LP or does the AUTO light not come on?
With the switch in the auto position, check for 12 volts between the red (-) and black (+) on the 6 position plug on the lower board.
The auto light is solid on AUTO, the LP light does not lit unless I switch the fridge to LP only. I tested the thermostat which works as well as the display control board.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
