hydrocynus
Mar 07, 2017Explorer
Chris Bryant wrote:
That is the correct board if the original had the integrated ignition module. Does the AUTO light come on but it stays on LP or does the AUTO light not come on?
With the switch in the auto position, check for 12 volts between the red (-) and black (+) on the 6 position plug on the lower board.
Chris, I was reading again your post. I am not sure what is needed to be tested here:
"With the switch in the auto position, check for 12 volts between the red (-) and black (+) on the 6 position plug on the lower board."
Can you please clarify? thanks a bunch
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
