Hello Im new at trailering and need some help. I bought WW 5th wheel 2008, and my fridge is not always cold. Freezer works great. Ok, when i bought the trailer the fridge was cold. when i brought ...
Moving the 'thermistor' will NOT correct a 40*F change in food section temps (only good for 6*-8*F change)
Overnight/early morning......temp 41*F but come late afternoon when it's hot outside temp goes up to 80*F. You have a 'draft' problem...insufficient air flow across cooling unit from lower vent thru upper vent OR your cooling unit is experiencing blockage inside cooling unit
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
