Freezer 'warm' & food compartment holding temp.
Freezer section gets cooling affect FIRST ----THEN food compartment
Fridge on 'coolest' setting and freezer NOT going below 26*F but food compartment at 32*F-34*F suggests obstruction in Freezer Low Temp Evap Coil.
Not a issue with circuit board, thermistor, LAC, Ambient air temps etc
Cooling unit process is functioning overall otherwise food compartment temps would NOT be at 32*F
If Freezer Evap Coil was fully functioning the freezer temps would be at 0*F or lower with those temps on food compartment.
Obstruction/Blockage.
What is MODEL Number?
RM1350?
Check Freezer Door Seals for leakage.....door bill test
But if the door gaskets didn't fully seal freezers should have excessive frost build up
