towhead
May 15, 2013Explorer
The tab you are referring to is probably part of the sheet metal wrap. When you get to the element removal, spray a little WD40 on it and twist back and forth to loosen it and it should slide out. I had a real fight removing mine till I used the WD.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
