restlessways
Feb 06, 2017Explorer III
Dometic NDR 1062 fridge quit, won't run on AC or propane
The fridge and freezer just quit. The "eyebrow" is still illuminated and I can switch to AC or propane, and the propane burner will even light, but the fridge will not get cold nor will the freezer work. I have checked the fuses on the lower control board, I have power from the 120v cord going into the control board, I have verified the thermistor is working (I had replaced it last year anyhow), and I have made sure there are no loose grounds or wiring issues. There is no yellow matter anywhere nor any smell of ammonia.
I am stumped. The only thing I have not done yet, due to horrendous weather, is check power going from the lower control panel to the heater while on AC power. I was a little nervous to do that because I did not want to get cooked. Can anybody help me figure out what may be going on? I fear the worst, that the cooling unit gave up the ghost. The reason being that if it won't run on propane even when it lights then that means it's not the lower control board. Is that a fair assumption? Appreciate the help.
