dougrainer
Aug 28, 2016Nomad
goldtop1 wrote:
Hey Doug, I don't follow, there are 6 wires coming down from the top. 2 yellow , 2 blue a red and a black. Plus two phone jack wires. If what you say is correct, what do these wires hook to? The same six wires off the multi zone module are the same color so I wired them color to color. I plugged the phone jack in for the T-stat and of course hooked up the 12VDC to the red and black wires to the module. All I get is heat. The T-stat flashes E5 and the temp set.Help!
You have to REMOVE the original Module. That module is a 5 button module. Those 6 wires and the Phone type connectors come from the 12 button module mounted on the top area of the Penguin. Like I stated, you messed up big time. You will have to go on top and set the DIP switches on the module on top. Did the penguin NOT come with a 2 x 4 metal box with the 120 wires in it? Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
