dougrainer
Feb 13, 2016Nomad
OK, ALL Penguins come with a 12 button CCC control board that requires the Phone type communication cable. Why would you want to spend money on a 20 year old used Penguin? Do you have the old style Flat Ribbon cable now or the Phone type cable? The problem is, there is NO room to wire and install the Dometic Analog control board you need for your mechanical controller. Is there a reason you need a Penguin? You could install a Brisk Air model and purchase the Analog control kit to used with your mechanical tstat. NO RVP or Dometic upper unit comes with a control kit other than the Penguin. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
