Larryect
Aug 27, 2018Explorer
MDKMDK wrote:
May not apply to this issue but I believe there was a recall on those awnings for a bad motor causing them to deploy while in motion. You might be able to verify by checking the model and serial numbers at the Dometic website. I had a 2013 Keystone Bullet (briefly) and got a recall notice for the awning. It rings a bell.
Thanks. The only recall I could find was for some 2013 units. Pretty sure mine is 2012. I will double check, because it seems the tag I found was specifically for the arm only. But pretty sure I bought the trailer in 2012, it is a 2013 model year.
