caver's avatar
caver
Nomad
Jul 07, 2022
Dometic reefer check light
I have a Dometic DM2652RBX 2 way fridge in a small 16'camper bought new in spring of 2020. Right before a trip leading up to Memorial Day I kicked the fridge on a couple days ahead of time before my trip Maybe a day or two later I noticed it had kicked off. This fridge has worked fine since purchased and had been used several times this spring. I reset it, it lit off and thought hmmm that's odd. I checked my propane bottles and all ok there. A day later it kicks off again. I wasn't going to cancel the trip so had to reset it sometimes in an hours time. I took a cooler along and used the reefer for stuff that could get in the 50's and not make me sick. A couple weeks and I was back home frustrated. I turned it on in this heat wave and has worked for over 48 hours. What I know:A It always relights.B It's not a movement problem as it has kicked off while at camp.C The flame looks excellent. D I tugged around on wiring while watching the flame so nothing loose. I asked a place that sells units and parts but they just said the CHECK light only applies to failed to light on propane. They suggested possible low DC to the backside of the PC board and that the unit was likely farmed out to a manufacturer in Japan or Germany if it has no outside frame (which it doesn't) One clue I do have is a week or two before lighting the fridge for that trip I found my deep cycle batteries terminal corroded. I turned off the master switch and when I hooked it back up my propane detector was switching on and off and I'm think the fridge was turning on and off too. I then realized even though it was an overcast day I neglected to pull my solar panel fuse while cleaning the battery terminals. I'm tempted to replace the lower board but hate to spend money on a board only to still have the problem.
  • Some propane detectors feed a solenoid on the propane tank feed that shuts off the propane. If equipped the propane detector must have a steady green LED before the solenoid is energized.
    Look for solenoid next to the propane regulator.
    Make and model of your rig?
    Make, model and age of propane detector?
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
