TRazzo's avatar
TRazzo
Dometic Refer Fan Issue
I have a 2011 Eclipse Attitude toy hauler with a Dometic refer. The fan cycles on and off every 30 seconds AFTER being "fixed" by the local dealer. Supposedly the fan will turn on when the temp gets above 100 degrees and then goes off below that. At first it was cycling every 7 seconds, they "fixed" it by replacing the thermal switch and now it is every 30 seconds. After returning it to the dealer upon further inspection they said the hole in the roof is too small, it is about 70% the size of the inside of the vent, plus there is a rafter going through the center of the hole, as is a bunch of wiring. I suppose it is possible, has anyone ever heard of a problem of like this? It won't be that hard to open up the hole (they wanted $400.00 to do it) but I don't want to waste the time if it is a refer issue not a circulation issue. Thanks all!
Tony
  • Don't let then mess wit the hole in the roof. They're grasping at straws because they don't know how to fix it or whats going on.
  • You have a another bad snap thermistor or it is touching something it should not be. It is designed to run with air temps and not be contacted to something that will dissipate heat quickly.
    If your refer is working normally other than the fan cycling access the device and see if they have it screwed to some fin that may cause it to cool quickly.
  • IIRC that thermodisc switch closes when temp goes above 100*F and then opens temp drops below 90*F.
    If outside ambient air temps are over 90*F then the fan is going to be running constantly
    Proper clearances for correct air flow (draft affect) is critical to good cooling unit operation on absorption fridges.
    The roof opening being smaller than roof vent and obstructed doesn't sound like the rv mfg. met Dometics installation requirements.
    Which model of Dometic fridge.....installation manuals will give max/min clearances & measurements needed.
  • I would be worried about the heat deteriorating the wiring over time.
    Why not call the manufacturer and ask them. Could be they took the obstruction into account when putting in the vent.
    I would troubleshoot by first putting a good digital thermometer in the went and seeing what the temperature actually is when the fan kicks on.
    http://www.eclipservmfg.com/contacts
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
