TRazzo's avatar
TRazzo
Dometic Refer Fan Issue
I have a 2011 Eclipse Attitude toy hauler with a Dometic refer. The fan cycles on and off every 30 seconds AFTER being "fixed" by the local dealer. Supposedly the fan will turn on when the temp gets above 100 degrees and then goes off below that. At first it was cycling every 7 seconds, they "fixed" it by replacing the thermal switch and now it is every 30 seconds. After returning it to the dealer upon further inspection they said the hole in the roof is too small, it is about 70% the size of the inside of the vent, plus there is a rafter going through the center of the hole, as is a bunch of wiring. I suppose it is possible, has anyone ever heard of a problem of like this? It won't be that hard to open up the hole (they wanted $400.00 to do it) but I don't want to waste the time if it is a refer issue not a circulation issue. Thanks all!
Tony
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
