PSU1999
Jan 25, 2007Explorer
Ok, this is directed to our RVing experts who have a level of experience. Assuming you have an affected unit that does not show any signs of failure what is your feeling on using it until fixed under the recall? I've read what Dometic has put on their website "don't use the unit on gas and if you need to use electric turn it off at night" how realistic is that? I have also read the initial post by Les where Dometic reported that there was a less then 1% chance of fire, which is very low. Furthermore out of all the units affected by this I'm certain there are people who are not on the RV net or who are second owners of their trailers and don't know anything about this and may never know. All of their RVs aren't going to be burning down. More than likely they will hear about this when the refer quits working. I guess what I'm saying that I will inspect the burner area regularly as instructed to look for signs of leaks and make sure my smoke and lp leak detectors are functioning however until the recall repair is made I'm going to continue to use my refer normally. Does anyone else feel this way?
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
