RJsfishin wrote:
wa8yxm wrote:
The best test is the manometer.. and I won't go into how to use it.
But the fridge is a Propane "sipper" not a propane "Guzzler" like the furnace or water heater. So if the latter work well. the first should regulator wise.
Some Fridges do work better on one or the other heat source.. Don't know why. but they just do. And some work better on one some on the other some don't care.
Just now. mine on electric is 34.1 degrees in the top door shelf.
That's correct, mine (and many) always did get colder on ac.
And if you think a new regulator is going to change that, good luck, you'll need it.
Funny, MOST responses over the years have stated they thought their RV refer operated BEST on LP and discounted AC current. But, RV refers will operates the SAME regardless of heat source. The reason some will state 120 is better or LP is better is because they do not understand the relationship on the fuel supply.
1. LP pressure is CRITICAL. NOT 11.5 inches and lower, it will not cool adequately on LP
2. NOT 118 to 120 volts but lower, it will not cool adequately on AC current. This is more a problem in CG's that have inadequate Electrical supply and with a lot of RV'ers, the line voltage drops. You need to monitor the line voltage with a DIGITAL Voltmeter. If it drops below 115, put the refer on LP for best results. Doug
