USAFBILL
Jan 28, 2007Explorer
QUOTE "As great as J-B Weld is, and I use it regularly, I wouldn't want to totally restrict any thermal expansion (movement) in a piece of tubing. If you were to restrict that movement, a failure could happen even sooner and you might void any possible Dometic warranty (if there even is a warranty!!). "
If you only covered the welded section (where I hear most failures occur) would that restrict any more then the weld does now? Mine is still under their extended warrany but I am not sure just how good that is now after all of this.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
