stevenal
Jan 29, 2007Nomad II
balvert wrote:
I doubt that Dometic will get their act together before we leave on a six week vacation so I am looking at installing the 325 watt element to reduce my chances of a problem. I will still get the fix done when Dometic makes is available, or is the fix going to reduce the amount of heat actually reaching the boiler tube? In that case the lower wattage element may prevent proper cooling. Not sure what the actual fix entails as it is rather vague in the recall info. Any thoughts on my plan?
Yes I have a thought. If microscopic damage has already occured, messing with it can only make it worse.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
