Lyman
Feb 08, 2007Explorer
Make : DOMETIC Model : NDR1062 Build Dates : APR 01, 1997 - MAY 31, 2003
Manufacturer : DOMETIC CORPORATION
NHTSA CAMPAIGN ID Number : 06E076000 Recall Date : AUG 28, 2006
Component: EQUIPMENT:RECREATIONAL VEHICLE
Potential Number Of Units Affected : 926877
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2663 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
DOMETIC / RM3863 9999
Recall Number: 06E076000
Summary:
CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS. 713XXXXX THROUGH 752XXXXX; 801XXXXX THROUGH 852XXXXX; 901XXXXX THROUGH 952XXXXX; 001XXXXX THROUGH 052XXXXX; 101XXXXX THROUGH 152XXXXX; 201XXXXX THROUGH 252XXXXX; 301XXXXX THROUGH 319XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV
Summary:
Consequence:
Remedy:
Notes:
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
