Empty_Nest__Soo
Feb 28, 2007Explorer
BettynLen wrote:
. . . My question is, are you still using your refrigerator and if so how? (All electric, run generator when under way, etc.?) If you are not using it what are you doing as an alternative? . . .
Dometic says to run it only on electricity until the recall is effected. I don’t have this option as I camp many miles from electricity. I had planned on using the camper probably four to six weeks this spring, beginning whenever the snow melts off of the Forest Service roads leading to campsites along my favorite trout streams.
I will use ice chests (and probably the refrigerator as an ice chest) until the dealer gets the part(s) and can install them.
I may cut back on the fishing trips as it is a minimum of 30 miles round-trip to buy ice.
I’m hoping it will be “fixed” before fall trout fishing, starting in mid-October.
I would likely use it on gas and pull the outside cover daily to check for leaks if I could be assured that I would see a leak before there was a danger of fire.
Wayne
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
