timsrv
Feb 28, 2007Explorer
Halftime wrote:
Tim, Where on the tubing were the failures you have seen? I hope he had good coverage.
Thanks, John
Failures I've seen occurred on the main boiler tube on the 1st weld up from the bottom elbow. This area is not readily visible as it is enclosed inside the sheet metal cowling and buried under fiber glass insulation. And no, he had no warranty or coverage. He has paid for each and every repair out of pocket. Tim
PS: on a side note, the original heating element was re-used each and every time cooling core was replaced. I had no knowledge of any potential problems here and didn't see a reason to replace it. In hindsight, I suspect that element killed all 3 units. The question I now have is: When did Dometic know about this? Evidently they knew something was up or they wouldn't have redesigned elements. A service bulletin about potential problems from Dometic would have been nice & could have saved this guy some money.....not to mention the risk. And yes, Dometic is now putting a high temp cut-off switch in this area on new refers. Tim
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
