WilleyB
Mar 04, 2007Explorer
I can see HOW to Install it but what about the wiring in the picture above it shows the thermostat connected the the (Flue?) but it does not show where the wires should be hooked up to...
Hi Lee in Calif
Have a look at the diagram in this link. Note the block at the bottom labeled 12Volt(+) and the black wire from it. This is the line to be interupted by the thermal switch. One wire from the thermal switch goes to the (12Volt(+)) terminal and the other wire from the thermal switch would go to the (J4)terminal on the board.
Dometic Electrical Diagram
Hope this helps you in understanding the circuit.
Willis
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
