rsg33
Mar 12, 2007Explorer
timsrv wrote:
...I can't see a problem swapping to the other pocket & think it's a good idea. Does anybody else here see a problem with it? Tim
Nope. The wattage of the 12V element in a 3 way fridge is the same as the 110V, so I see no problem in switching pockets.
Edit:
Upon further investigation, the above is not true for newer double door fridges. The older units had same-wattage elements, but the newer units have much lower wattage on the 12V side. I should do more research before shooting off my mouth.
I still see no reason for not being able to use the 12V pocket as an alternative. The element pockets appear to be constructed with the same guage material.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
