Claude_B
Mar 27, 2007Explorer
I too received my letter from Dometic and made an appointment for the recall. Now, I look back at page 41 of this thread (pictures) and knowing that the hotest part of the 120 volts heater is the tip of it and the most critical part of the well tube is where the weld begin (exactly where the crack is located), I wonder if raising the element by 1 or 1.5 inch in the tube would help so that the max heat would be away from the beginning of the weld. I think it is fairly easy to do just by adding a stopper (peace of metal sheet and small screws) where the element start the 90 deg bend. May also have too cut a bit the top metal sheet and I will of course replace the actual element (38.2 ohms) with a 325 watts model. What do you think ?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
