J_Walker
Apr 06, 2007Explorer
WilleyB wrote:
From previous posts on this thread, when the cooling unit fails and the coolant is lost, tremendous heat will be generated in the boiler area which "could" lead to a fire. The thermal switch would then shut down the 12 volts to the board preventing further heating. I'm guessing that's what it's all about.Willis
The fire danger exists when running on propane which ignites the coolant if it escapes. Note that Dometic recommended that we use electric only until the recall is installed.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
Willis
