WilleyB
Apr 18, 2007Explorer
Hmm! perhaps you're thinking autotransformer which will work fine. A transformer connected as you suggest will also work fine as long as the current requirements of the element and transformer capability's are respected.
My humble efforts Click-->
Now the key here will be the leads of the 6.3volt winding. In series aiding you will get 113.7 volts output for the element, however by reversing the the lead connections it would give a BUCK situation which would further decrease the voltage to the element.
So in the AIDING situation where you'd get 113.7 VAC for the element, a 40 ohm element would dissipate 323.2 watts, that's close enough.
Willis
WillisAbout Technical Issues
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
