Claude_B
May 02, 2007Explorer
Well, mine is done and from my experience, I would advise you to carefully check when the job is completed, if the sheet metal with the electrical drawing (see WilleyB post with pictures on page 52) doe's not get in contact with the plastic vent cover bacause in my case, it was blocking at least 40 % of the vent. I noticed that at home so I rework it to make sure there was enough clearance for the cooling air to circulate. This maybe the reason why an earlier post (96Bounder...) parent's fridg did not work properly after the recall was done. Now, am I impressed with the kit ? To be honest, they could have done better ! Anyway ! And I did install a dimmer to control the power of the element. The fridg is on a test run at the moment. I will let you know.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
