Desperado359
Jun 03, 2007Explorer
I pulled the refer/heater fuse. The refer is off and I pulled the light out, so there should be no power use. I also looked at the Dometic site and went to my refer page, on page 11 at the bottom it talks about the CC, it says if it is on, it will draw 12v all of the time and you should have a charging source to keep the batteries up, so I think I may have found my problem (I think the CC is on)I will check it out tomorrow after work and will post if that is what may be happing. Thanks again.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
