Just_Lee
Jun 17, 2007Explorer
Skeet25 wrote:
Lee, This is what edge540 said about the same problem.
Had my kit installed two days ago. Now doesn,t work. Yes it worked fine on gas or 115 vac. prior to retrofit. I removed fount cover of the kit 5x8 sheetmetal now it works. Guess it restricts draft up the flew. If you haven,t checked yours on gas, may be you should.
Thanks Skeet25..... I WAS trying mine on GAS... I removed the sheetmetal and it seemed to help.... Now I have to try it on Electric..... Hmmmmm I wonder if others are having the same problem?
Does Dometic need to re-think what they are doing? Some times BANDAIDS leak........ In other words they DON"T work........
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
