kerryedwards
Jul 23, 2007Explorer
Had the recall fix done. After 4 days of use, frig failed. No lights at all so I figured it was a lack of power. Called Camping World which did the fix and asked them if anything in the recall work would cut the power. Answer was no. After waiting for 20 minutes to talk to a tech, I gave up and called Dometic. Asked the tech there if anything in the recall would cause frig to lose power. Was told no, and that I probably had a bad circuit board. Didn't really believe this given the timing so started doing some investigating. Found power going to the initial wire going to the frig but no power coming out from the same wire once it disappeared behind the additional metal work. Disassembled the recall metal and found a failed diode which had been added during the recall.
Called back Dometic and they finally admitted that the failed diode (thermal fuse) would cause a power failure. I then tried to figure out if the diode failed due to overheating or a bad diode. Measured the temperature of the burner (running with the diode jumped) on propane at a high of 300 degrees in one small spot with most of the chimney surrounding the burner in the 150-200 degree range. (measured with an infrared thermometer) Called Dometic and tried to get them to tell me what the normal operating temperatures were. They refused to tell me. I argued with them for about half an hour. Got nowhere. Called them back the next day and kept insisting that I wanted the info (which they denied they had) since I suspected that they had installed a diode that would fail at a low temperature to further limit their liabiities. Finally they told me that 300 degrees was a safe operating temperature.
Since I was 4 days into a month long roadtrip, I had to pay $85 for a service call for a tech to replace the failed diode. The diode was installed within about one inch of the hot portion of the burner chimney. Tech said diode was installed too close and failed because of this.
So, be warmed, the recall can cause the frig to fail and Dometic will deny that the recall had anything to do with it. It is in their interest to deny the connection and get the consumer to replace their frig since it takes a frig which is a liability to them out of service.
I would like to know the exact temperatures at which the diode is designed to fail and also the temperatures of the limit switch which is installed in the burner chimney.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
