charlan
Jul 30, 2007Explorer
timsrv wrote:
Make sure it's plugged in and it's 120v outlet has power going to it. There are also a couple of fuses under the circuit board cover. If the 120v fuse is blown, or the outlet is dead, the refer will act exactly as you describe. If all these things check out, then it's most likely a faulty circuit board. Tim
The boogers forgot to plug it in when they did the recall, oh well we cant all be perfect, especially RV tech's. :S After all they only get 40 minutes to do the recall and not plugging it back in saves some time.:B
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
