kerryedwards
Aug 02, 2007Explorer
Picked up a couple of thermal fuses at a Radio Shack store yesterday. The fuses have a coned end and a flat end. The packaging says the flat end is the sensitive fused end and to locate the fuse with this in mind. The closer the flat end is to the heat source, the quicker the fuse will activate. If the Dometic fuse is similar, this is worth knowing when placing the fuse in its holding bracket.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
