bobandcat
Aug 03, 2007Explorer
I had my recall kit installed yesterday. It took about 20 minutes and I was on my way. I watched and talked to the tech as he was installing it.
The mounting bracket for the thermal fuse was bent 90 degrees so that it was not touching a hot surface. I also kept the original red power wire so that if the thermal fuse does fail, I can just re-install the original wiring thereby bypassing the thermal fuse wiring until I can get a replacement fuse.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
