mikew9
Jul 03, 2008Explorer
Lee In Calif wrote:Skeet25 wrote:
Lee, This is what edge540 said about the same problem.
Had my kit installed two days ago. Now doesn,t work. Yes it worked fine on gas or 115 vac. prior to retrofit. I removed fount cover of the kit 5x8 sheetmetal now it works. Guess it restricts draft up the flew. If you haven,t checked yours on gas, may be you should.
I took my TT in yesterday got it back today. On 110VAC the freezer got cold quickly (1/2 hour) and just short of two hours later the lower refigerator section was definitely cool. I shut it off and left it to warm back up for several hours. I then switched to LP mode. Freezer gets cold quickly (under an hour) but after 3-4 hours there is no indication of any cooling in the lower fridge section (the fins are warm). Bahhh! I will leave it on LP overnight and check it in the morning.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
