Chris_Bryant
Feb 15, 2009Explorer II
The recall adds a couple of safety devices before the circuit board. A fairly common problem is when the new wire between the junction block and the first thermal fuse isn't making a good connection (which should be caught when the service center *tests* the recall installation).
Check for 12 volts at the thermal cutoff riveted to the chimney- both sides.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
