Dusty_R
Sep 04, 2009Explorer
cvrvr wrote:
The fix that Dometic is using is at best a bandaid fix.
There is only one way to really fix Dometic (and Norcold) problem is to replace the cooling unit with a remanufactured unit made by rvcoolingunit.com or someone simalar.
If you replace the entire refrigerator with a new Dometic or Norcold you can still have the same problem. If the rest of the refrigerator is in good shape, just replace the cooling unit.
George
If I remember right Norcold did fix, repair, or replace the cooling unit or the refrigerator.
Dometic did the band-aid thing, just prevented it from catching fire if/when it leaked. Maybe they figured that the percent that might catch fire was small enough not to do the job right.
Dusty
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
