dougrainer
Sep 05, 2018Nomad
Control Boards NEVER cause this problem. ALL the control board does is respond to the Temp Thermister to turn the refer heat on and Off. So, OHM readings on a Thermister are useless. BAD Thermisters will ohm correctly. Just replace the Thermister, That is your problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
