2edgesword
Sep 05, 2018Explorer
The ohm reading of a thermistor will vary with temperature (increase or decrease depending on whether it's an NTC or PTC thermistor) and the system is set-up so that when the thermistor resistance reaches a certain value the frig will either cycle on or off. Again, not knowing the details I'm not sure of the which is which but I would think moving the thermistor from top to bottom will prolong the time the frig runs if it takes longer for the bottom of the fin to get cold (which I believe is the case). Moving it from bottom to top will shorten the time the frig will run.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
