dougrainer
Sep 06, 2018Nomad
goldwinghauler wrote:
Final question for all you tech guys, can the eyebrow control panel be switched from fully automatic to fully adjustable?
Below is from Dometic. You need specific Part Numbers of the lower control board. The "product" of the refer refers to the 3rd number on the serial sticker. Model===Serial===PNC. PNC stands for Product number. Then you need the Part Number of the lower control module. Doug
Yes you can.
What is the product of the refer?
There are two different upper controls with adjustments.
What is the part number of the lower board
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
