goldwinghauler's avatar
Sep 06, 2018
Dometic Refrigerator gets too cold
I have an 8 cf Dometic DM2852. Instead of the usual gets too hot inside, mine runs about 28-29 degrees, causing items to freeze. I contacted Dometic (useless phone call). They told me to take it in for service. I’m in between camping trips so I took it in yesterday. The tech checked the thermistor and its value on the cold test was 400 ohms less than the minimum. They told me to go home and run the fridge to test it again for 24 hours. I did that and called the Service guy today at 11:30. He said it has to be a bad control board. Thanks to Dometic for assigning another tech person to the case. With another wasted day. Open the fridge for 30 minutes, move the thermistor to the bottom of the right fin and call back in 24 hours. That’s tomorrow. We leave on Saturday for two weeks of camping including a Truck Camper Rally in Gettysburg, with a busted fridge. Quite sure there will be another BS solution tomorrow and no time to get parts ordered and installed by Friday night.
Help, Help, Help what should I do or try?
  • Control Boards NEVER cause this problem. ALL the control board does is respond to the Temp Thermister to turn the refer heat on and Off. So, OHM readings on a Thermister are useless. BAD Thermisters will ohm correctly. Just replace the Thermister, That is your problem. Doug
  • Slide the Thermister to the bottom of the outboard cooling fin or cycle the fridge manually, 12 on, 12 off.
