Denny___Jami
Sep 03, 2016Explorer
A easy way to figure out if it's the cooling unit or the control is to take the electric heater wires and wire it directly to 120 volts. If the unit cools properly it's a control problem if it doesn't it's the cooling unit. If when the dealer changed out the cooling unit and didn't seal around the outside area where the cooling cools are the unit will not work like it should.
Denny
Denny
