dougrainer
Jul 29, 2022Nomad
Tapping and rotating the refer is called "Burping". NEVER WORKS---NEVER. If not a leaker, then it is blocked. Tapping and turning over and over just manually realigns the Ammonia. Once it starts circulating again the blockage will return. The blockage is INSIDE the upper coil close to the evap. It is as hard as a weld and can only be repaired by cutting out the upper coil and welding a new upper coil. Then recharging. I would buy a new replacement. Doug
https://www.dometic.com/en-us/outdoor/food-and-beverage/refrigerators/rv-refrigerators/dometic-rm-2193-30914
