revickers's avatar
revickers
Dometic Refrigerator No Power
I think I know what I did. When I was washing my RV, I accidently sprayed water in the refrigerator vent. When we got to our next campsite, I turned the refrigerator on, everything seemed fine, but then about 15 minutes later, the power went out. I checked the fuses - 3 and 5 amp and they were OK. But when I checked the 15 amp, it was blown. I replaced it thinking I solved the problem. Well, it still did not work. I checked the 15 amp again and it was OK but still no power. No lights, fan, no electricity at all to the refrigerator. Could it be the board, how do I know. I am now going to replace the 3 and 5 amp, even though they are OK. Any other suggestions?
Thanks,
Reggie
  • DO you have any panel lights?
    No panel lights........NO DC power going to fridge
    Do you have a 'recall kit'........high temp sensor installed on burner stack?
    If it trips it shuts down ALL DC to fridge.
    It has a manual reset button.....could have gotten wet.
    3A fuse on circuit board is for the DC circuits
    5A fuse is for the 120V AC electric element only
  • GFI IN TRAILER POPPED?
    SOmetimes 3 or 4 outlets are covered by on e gfi
