j-d
Jun 24, 2014Explorer II
Ideally flue done down from above and baffle has to come out. Hard to do without disturbing roof vent. You can reach up from below and rap with screwdriver handle. Then clean burner area.
Some shops can test a board. See if you can hardwire the AC element to an appliance cord and run direct. Should draw two.something amps
But make sure door gasket is sealing all around!!!
