Old-Biscuit
Jun 13, 2015Explorer III
Error Codes:
The codes are displayed by flashing temperature setting LEDs.
After having solved the problem, turn refrigerator OFF and then back ON. The refrigerator will return to normal operation.
3 LEDS
1st LED flashing-----------Disconnected gas valve or hardware fault in the gas operation system.
1st & 2nd LED flashing-----Overheating thermostat is disconnected. •The cooling unit has been overheated. Service is required.•
2nd LED flashing-----------A faulty temperature sensor device or a fault in the associated electronic circuitry has occurred. Make sure the sensor wire is connected.
3rd LED flashing-----------DC voltage is out of range (exceeds or drops below the limit values approx. 8-18V DC).
ALL 3 LEDs flashing--------No communication between display and power module.
3 LEDS
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
