dougrainer
May 21, 2014Nomad
Take the Control box cover off the control box behind the refer. Look at the epoxy that the circuits are imbedded in. IF it is yellow/beige, then your control module needs replaced. If it is greenish, then check the Thermocoupler or the spark ignitor which ever your unit uses. Dometic used both depending on the model number. Doug
