- DesertHikerExplorerThank you!!
- BlacklaneExplorerBy the way, if the clip does not stay on the fin, you can tighten it with a Clam Clip, binder clip, paper clip, or any number of products found in office supply stores.
- wa8yxmExplorer III
enblethen wrote:
Could be the thermistor cable.
Model of refer?
My Guess as well
Right side near the top? If so that confirms it. Shoudl have a plastci clip on one of the right most fins that is supposed to hold it. - This is what the thermistor looks like along with the bracket for attaching to the fins.
Thermistor - DesertHikerExplorerIt is a Dometic DM 2652 which is the model with “Automatic Refrigerator Temperature Control” And I do have a bracket in my fins, so I will try playing with that ... thank you!
- IAMICHABODExplorer IIWhat the other posts have suggested This Video will show you what it looks like.
Th clip that holds it to the fins may be missing. - bob213ExplorerIf it is the thermistor, there should be a white clip on one of the fins that it goes into. Generally goes on the farthest to the right fin or next to it. Up position makes the refer colder and lowering it warmer.
- bukhrnNomadShould be a plastic bracket that fits onto the cooling fins,the end of the "cord" fits in, the bracket, sliding the bracket up or down controls the refrigerator temperature.
- bukhrnNomad
enblethen wrote:
bingo
Model of refer? - Could be the thermistor cable.
Model of refer?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
