Chris_Bryant
Dec 08, 2015Explorer II
I'm pretty sure that thermostat is still available, but in the mean time, there is a bypass screw on the top of the gas side (back), this is a different tstat, but the layout should be the sane:
Remove the bypass screw and you will see a tiny o-ring at the bottom (small end)- remove this o-ring and reinstall the bypass screw- you will now have full flame at all time.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
