Old-Biscuit
Jun 03, 2014Explorer III
Depending on model year (serial numbers) the Dometic RM2351 used a 'thermocouple' and later model year uses a spark electrode (which is the flame sensor).
Your main flame is lighting off (good spark) but won't stay lite because circuit board is not getting the flame proof signal....either bad sensor (likely) or bad circuit on board
Dometic thermocouple....part #2932052018.......LINK
Dometic spark electrode....part #2932781012.....LINK
Before replacing....pull thermocouple/spark electrode (whichever one you have) clean the connection at board...make sure it's tight and clean up thermocouple. Spark electrode gap should be 1/8" and both need to be engulfed in main flame.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
