hhornig
Jun 04, 2014Explorer
Chances are that your thermocouple or your circuit board is bad. Remove the thermocouple and hold the tip in a gas flame with a multimeter across the leads set to the millivolt range. The voltage should be somewhere in the 20-30 mv range. If it is the circuit board is bad. If not in the range your thermocouple is bsf.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
